RCU Forums - View Single Post - F-8 Crusader build
Old 12-05-2006 | 05:42 AM
Paternguy
Default RE: F-8 Crusader build
Looks good.
The only thing I see that you might want to change is the hinge line for the rudder. You may want to make it 90 degrees to the thrust line to avoid any roll coupling when the rudder is applied.
You also might want to increase the size of the horizontal stab by 10% to add extra stability to the design.
