RE: Mayhem, Showtime, or Inspire?
I would recommend the showtime -- I really enjoy mine. I would definitely get some decent servos for whatever plane you buy. If you over-do it on servos with the Showtime, or some other similar plane, you can move them into a 30-35% plane and reduce the cost of that plane by moving your gear over. I have hitec 5645's in my showtime which now are pretty inexpensive -- maybe 5-10 dollars more than the hitec 645's. I also put a lithium ion set up with a regulator in the Showtime. My idea is that this equipment will be sufficient for a 50cc classed plane when I make the move.
