RCU Forums - View Single Post - Problems Drifting
Old 12-06-2006 | 03:40 PM
MDdrifter
Default Problems Drifting
I have a stock TB-02 skyline. I usually drift on asphalt. Right now I'm using PVC tires and I am the best when it comes to doing donuts and getting pretty good at making long slides. When it comes to going straight forget it. When I do complete a nice slide the car will sit and spin before it moves, or I will finally get up some nice speed and try to make a turn and the car keeps going straight. And trying to make quick sharp turns back and forth are a no go. Like I said everything is stock with some suspension adjustments. I am thinking of getting a set of drift tires. Either the Tamiya, or Yokomos, will the yokomos fit on the TB-02, or do I need to stick to Tamiya's. I am guessing that the yokomo rims will fit the tamiya cars? Also if I switch to either, will the stock motor have enough torque to get it sliding?
