Installing the Main Shaft and Swashplate...
My first real tip for the MaxiR... I have a great selection of dill bits and after scratching my beautiful blue MaxiR SE Rotor Head, I was determined not to let that happen again and somehow find an easier way to insert the jesus pins in the main shaft. So, I measured the pin that came with my SE, it was 1mm, it's a tight fit in the aluminum Rotor Head and I had a dificult time measuring the ID accurately enough to be sure of its size(no pin guages here at home). So I took out a #60 drill bit, THIS is not a hardware store drill it, it's a bit sold for use in industrial applications, very precision, I chucked it up in my pin vise and bored the Rotor Head cross hole and the cross hole in the main shaft. What I found was the main shaft hole was already sized to 1mm or #60. But the Rotor Head was an extremely tight press fit 1mm. After boring by hand with the #60 bit in my pin vise, it was a perfect press fit with the included pin.
I did this same thing on this one before I even tried to instal the pin and no more scratches and a fairly easy installation(the perfect press fit), also no way is the jesus pin falling out. But I can remove it if neccessary.
After the main shaft is installed, it's time to install the swashplate...
Ken
