RE: Problems Drifting
OK.. Here is Your Main problem : Car Control..
You need to Adjust Your Throttle inputs and Steering inputs constantly..
Driving Straight wont happen, to Drive a Car on ABS/PVC Straight requires constant Steering inputs..
You cant Just Nail the throttle and the steering and not expect to spin...
When Your Car Feels like it is gonna spin, Pulse the throttle and start using Opposite lock to correct it..
Pulsing the Throttle allows the Car to Grab Traction and Release it in quick Successtion giving it more control..
As For the Car going Straight Through corners , Your Going too fast and momentum is Shovel noseing the Car forwards.. Back off the Accelerator, the car will regain traction then you can re apply acceleration...
It Takes Practice to learn what the car will do on ABS/PVC it is not the same as Driving on Drift Radials or Rubber..
Just Remember, Dont Hold the Accelerator Flat Stick and Dont over turn..
