RCU Forums - View Single Post - Ignition-Magneto 5.8 only sparks when turned over extremly fast. Can't hand start .
Old 01-26-2003 | 01:29 AM
tkg
Default Start
Well if you don't want a big electric starter or a battery cdi, then you need a bigger arm. Sorry thats life
Most mags need 700+rpm to fire. Read the Zenoah instructions about prop placement vs mag. That might be enough to get you started. But a 5.8 is a big sucker and there is a lot of compression to slow you down.
There is no jump start for Sachs engines
Good luck.
