Ignition-Magneto 5.8 only sparks when turned over extremly fast. Can't hand start .
For a cheap high torque starter for my g38, I use my 14v cordless drill with a starter cone. I use a cone from a standard starter, run a 1/4 20 bolt though, and secure it with a blindnut put on backwards (pointies out). Just chuck it into your drill. I'm sure the higher volt drills would do even better. Best part, you have a drill at the field too!
