RCU Forums - View Single Post - Three Real Basic Beginner Builder Questions
Old 12-07-2006 | 11:22 AM
BHunn3
Default Three Real Basic Beginner Builder Questions
Help a beginner out:
1.What glue (i.e. CA, epoxy, carpenter, etc) do you recommend for which purpose (sheeting, gluing sticks together, balsa, hardwood, etc)
2. What technique do you use for gluing control surface, fuselage side, wing panels,etc, together? I.e., put the glue on each end/surface, then put together? or position, pin and then slop glue on joint?
3. How do you keep from gluing the pieces you have postioned on a board - to the board?
