RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 12-07-2006 | 11:46 AM
  #4477
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: navihawk
the main blades start to spin and the tail motor doent, i have to nudge it sometimes. Other times it starts up normall? Could that mean that its time to get a new tail motor? I think it does but im not sure. Thanks.
I would definitely swap the tail motor. It sounds like the brushes are binding and it's very difficult to "nudge" while in flight. By lipo I assume you went with 3s, and by doing so had to change to the 8 or 9t pinion. If you didn't change the pinion that would explain your tail problem. They burn out very quickly on 3s with a 10t pinion. Also be sure to add the heat sinks if you don't have them.
