Glow Plug Voltages
Have you tried a drop or 2 of fuel down the carb to prime? 1.5E should be pleanty if there is compression and fuel. It should pop a few times. If it does and that is all you can get to happen, you may have some kind of blockage or air leak in the fuel line.
Try priming and see what happens.
Good luck
Jimmy
