RE: Problems Drifting
magnat is telling you correct, I will add to that . If you are just starting at drifting and it sounds as though you are, DON'T use full throttle yet, go real slow and I mean real slow when starting off to prevent spinning. When you start the turn let off the throttle and apply slowly while turning. Just before the rear comes around turn back to counter the rear from going all the way around and apply and release throttle till you get the hang of it.
Go slow at first till you get the hang of it. It is all in the throttle and steering. Your fingers and wrist will get tired before you get the hang of it. It takes a lot of practice.
