RCU Forums - View Single Post - FS One by Hangar 9
Old 12-07-2006 | 10:35 PM
  #503
LearJet1
Default RE: FS one by Horizon Hobbies
Just finished loading FS-One to both of my computers. Loading took ~50 minutes for each comp. After installing, I ran the latest 1.0.4 revision.
This gives the results of two setups that work with FS-One.
The simulator runs fine on both machines with no problems. You do need the FS-One controler to be inserted into the USB bus of the machine that you want to run the simulator on. I will probably use the laptop for most of the time.
This is a very good simulator and I believe that given a few months to mature that it could be one of the best.
Below is the short results of running dxdiag.com and saving the results.
Desktop System Information as reported by dxdiag.com
Gateway 750XL Desktop Purchased 2002
System Information
Time of this report: 12/7/2006, 03:39:34
Machine name: DEN-ES1X4J
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: E-4650
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) 4 CPU 2.00GHz
Memory: 1024MB RAM
Page File: 330MB used, 2131MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: RADEON 9550
Manufacturer: ATI Technologies Inc.
Chip type: ATI RADEON 9550 AGP (0x4153)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4153&SUBSYS_02001092&REV_00
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6648 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/11/2006 18:44:09, 260608 bytes
Laptop System Information as reported by dxdiag.com
Purchased 2006
Time of this report: 12/7/2006, 10:45:01
Machine name: N500XL NOTEBOOK
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
System Model: Gateway M465
BIOS: Rev 1.0
Processor: Genuine Intel(R) CPU T2300 @ 1.66GHz (2 CPUs)
Memory: 1022MB RAM
Page File: 341MB used, 2115MB available
Display Devices
Card name: ATI Mobility Radeon X1400
Chip type: ATI Mobility Radeon X1400 (0x7145)
Device Key: Enum\PCI\VEN_1002&DEV_7145&SUBSYS_0461107B&REV_00
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Version: 6.14.0010.6601 (English)
Driver Date/Size: 2/28/2006 06:57:30, 256512 bytes
