RE: IMAC rules on aircraft.
The only thing the wingspan is used for is to determine scale. To answer your question about wing vertical movement. You can move the wing up or down 10% the max. height of the fuse., usually measured at the highest point of the windshield. So in this example: If the fuse is 10" tall at it's max height, you can move the wing up or down 1". That is how I understand this rule, and seen it used at the unlimited level.
