Tail Pitch Slider Assembly Completed...
The last thing to finish the assembly of the tail Pitch Slider Assembly is to install and secure the two Tail Blade Pitch Pins, Put them in place in the holes in the slider(pay attention to orientation) and apply just a pin drop of thick CA over the back of the pin to secure.
EDIT: A good tip came from COBRA, wait until you install the tail rotor hub on the tail shaft and install the blade grips BEFORE gluing the Tail Blade Pitch Pins in place... Here...
Do not make a mess with the ca, you're working very close to small parts and bearings that need to rotate absolutely freely......
Ken
