RCU Forums - View Single Post - Fueling problem
Old 12-08-2006 | 04:16 PM
JPGale
Default RE: Fueling problem
ORIGINAL: Squire
Completely cowled in engine. Cannot get to fuel lines. Have 3 line system at tank. When refueling how do I determine when the tank is full short of filling up the muffler till it runs out???
No, I cannot disconnect the pressure line from the muffler.
No, I cannot disconnect the line to the carb.
A "T" fitting in the pressure line will not work as fuel will come out of both sides.
I'm using an electric pump so I can't count turns of a nand pump.
There's gotta be a way. I'm stumped.
Any help will be appreciated.
Phil
The fuel will simply come out of the muffler.
