RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 12-08-2006 | 10:04 PM
  #292
choppersrule
Default RE: E-FLITE BLADE CP PRO
Ifixairplanes,
See attached before and after cloaking.[8D] In the cloaked mode, the helis is about 3 feet in front of me and about 2 feet off the ground.
Glad to hear your making progress and having a lot of fun doing some modes.
If you get the super skids, get the Super Skids Version 3. It's much more beefy than Version 2, the skids are a little longer and the battery tray is bigger. So you can put in a 1200mAh battery with no problem. With Version 2, the 1200 battery won't fit.
It's a little more $$$, but you'll be glad you did. I have the V2 on my CP and the V3 on the Pro. See picture, V2 is on the left and V3 on the right. I think they are almost indestrucable. Also, the battery tray that comes with V2 or V3, you have to use rubber bands to secure your battery, if you use the velcro tape, just use the original battery tray from your existing skids. Buy the kit, not assembled one. Only takes about 10 minutes to put together and mount on the Pro. Everything is included, nice outfit.
Had to turn off the omni-port cloaking treslin modulator, so you could see them.[sm=49_49.gif]
Here's a link to Super-Skids V3: http://super-skids.com/
Just having fun, you do the same,
Dave / Choppersrule
ID:	573990   Click image for larger version
ID:	573991   Click image for larger version
