RE: new Tx(Futaba 6exh)
I took the crystal out of my blade tx and put it in the 6exh.. and used the settings sent to me by Kevin (thanks man) . the only issue I am having now is that the left Aileron servo is getting pushed all the way up and is not responding to the tx. One thing I could not program was the Swash plate.. It shows 1-5 and I can't figure out how to change it..[&o] help me! LOL! Never mind! Iset the swash plate and fixed the servo issue! Now I need to change the pitch curve because it won't lift off. Dang it! also I changed the pitch curve and noticed the swash plate is backwards (stick right - plate left) .. now to fix that what should I do?
Update.. I'm flying again! I screwed up and had the CH A on the swash at +80 instead of -80.. I had her in a hover and did a few tail in circles in the garage! Now just set the expos a little looser because right now they are touchy! Thanks Kevin!
