RE: Fueling problem
allot of my way is better stuff here, pretty confusing if I did not have a set up already in place that works fine for me.
I wonder if anyone has used a check valve and how do you explain how the air escapes to the beginner trying to set his plane up wasn't that the question? how about some photos of your supposed set ups and what parts are you people using instead of insulting each others fueling methods.
I use a EZfueler and have had no problems and also fuel dots they both work fine.
one thing I do know if you don't vent your tank when filling, you will flood your engine if your going to pinch the vent line off to prevent the muffler from filling with fuel.
if you are using a check valve then show the complete system and the actual parts being used, so there is a complete vision of what parts are needed and where to get them.
I knew what was being said, but is a beginner trying to figure out something he has not done before?
