RCU Forums - View Single Post - Fueling problem
Old 12-09-2006 | 09:54 AM
RVman
Default RE: Fueling problem
ORIGINAL: bruce88123
ORIGINAL: RVman
ORIGINAL: MinnFlyer
Just add a check valve between the "T" fitting and the muffler.
Muffler pressure can go IN, but fuel can't go OUT
I do not believe this will work. Once the other fuel line out of the T fitting is plugged after fueling, when the engine runs the muffler will pressurize the tank. But, go to full throttle and pressure will keep building up in the tank. Now go to idle and all that pressure in the tank that cannot escape through the vent tube because of the check valve will flood the engine right away. There is no way you will be able to get the engine to run correctly with a check valve.
To avoid filling the muffler, put a break in the muffler line that can be accessed from outside the cowl and disconnect it, fill the tank, then connect the tube back again when done filling tank.
Tom
I've seen the check valve used many times w/o the "T" and it works just fine. It helps to maintain constant pressure at all engine speeds. It's actually an old trick used for years.
Well i have tried it and it definitely doesn't work for me the engine always floods out at low end. A check valve can only work when there is a regulator like a cline in the carb line. Maybe this is what you saw, a check valve and regulator to go with it.
