RCU Forums - View Single Post - Hobbico Electristar Select EP Trainer RTF
Old 12-09-2006 | 02:49 PM
Greg Covey's Avatar
Greg Covey
Default RE: Hobbico Electristar Select EP Trainer RTF
Manuals are supplied for the ElectriStar assembly and Futaba radio setup. A data sheet is included for the installed R168DF dual-conversion, full range 8-channel receiver and an addendum showing proper installation of the prop adapter onto the motor shaft flat spot is also supplied. Note that channels 5-8 on the receiver are not used in this model.
ID:	574246   Click image for larger version
ID:	574247   Click image for larger version
