RE: DA-50 Long Idle Down Problem
These simple carbs are not gonna produce a best mixture thru the range on every engine they are fitted to
...some compromise is inevitable, you might have found the sweet spot for transition, but its obviously too lean on the bottom on this particular engine
swings and roundabouts
p.s., I know nothing about correct prop for da50 and assume the reccomendations above are correct, but overpropping is not the cause of the symptom you describe
