That won't be the problem. Something has to be slipping somewhere. Might want to check the clutch bell and clutch shoes? They could be glazed over or worn?
Also, more teeth on the spur gives you more acceleration, less teeth on the spur give you more top end.
ORIGINAL: djheptic
ive done everything you said 46u and all seems to be fine. could it be because ive added the tsais nitro devil pipe so its giving me more perfromance so i need more teeth on my spur gear?
