RCU Forums - View Single Post - Hobbico Electristar Select EP Trainer RTF
Old 12-11-2006 | 07:20 PM
Greg Covey's Avatar
Greg Covey
Default RE: Hobbico Electristar Select EP Trainer RTF
Simply click on the link in my first post to go to Tower Hobbies for the price.
The prop adapter was secured to the flat spot on the motor shaft by first applying some ZAP Z-42 thread locker to the set screw and then tightening it with the supplied hex wrench. The prop, spinner, and backplate all fit perfectly without modification. The prop is secured by a second larger supplied hex wrench and the spinner is secured by two supplied screws.
ID:	575441   Click image for larger version
ID:	575442   Click image for larger version
