RE: Walkera DragonFly #35 CCPM Electric RC Helicopter Reviews
jlarm77, just change the servo. word of caution with servos...different brands have two of the three wires on the plug in different sequence. if you are getting a different brand servo, be sure you match the color code against your original servo. red is positive , black (or brown) is negative and white (or yellow) is signal. compare the plug wiring of the new servo to the original and be sure to plug it into the receiver correctly. also check the new servo to be sure it is moving in the proper direction versus stick input. you may have to reverse the channel switch.
