RCU Forums - View Single Post - SR Eindecker E1 Winter Build Along…
Old 12-11-2006 | 11:19 PM
  #114
nickbee
My Feedback: (7)
Default RE: SR Eindecker E1 Winter Build Along…
Here’s an instance where I’m going to deviate from the manual. The balsa wing tip edging (top and bottom) is added after the wing tip is glued to the wing in the manual. I’m doing this pre-game for a reason that will clear later. Take note that the top edge is longer than the bottom. Everything gets a coat of finishing epoxy and the weight treatment.
So far my only gripe about the kit is the lack of certain side views on the plan. It makes figuring out which parts go where a little more difficult. But I guess if you just follow directions it is never an issue.
ID:	575652   Click image for larger version
ID:	575653   Click image for larger version
