ORIGINAL: TooSlow2Care
don't know about the car it's self, but i drift my old yokomo SD SSG racing chassis.
minor toe in, on the front maybe 1-2 degrees, 0 camber (it won't help anway with plastic tires) the shocks however should be setup a little softer than the manual says to. also make sure you DO put on the anti-sway bar on the front.
0 camber, 0 toe on the rear. no anti-sway bar in the rear, stiff shocks in the rear, and lock the differential will blue tack / silly puddy. all you do is cram a little into the diff. (search and you will find threads on this)
hope that helps,
BV
I think the rear differential is solid stock.. Thanks for all that info BTW!
