RE: My new engine
The prop I would use to run in the engine would it be the same one as the normal prop you use while flying the plane after running it in? If the prop had to come off during flight (this after running in on a nornal flight) would you shut down the engine so it wouldnt damage the engine or just idle?
Thanks a lot
Matthew
