ORIGINAL: Vampire
Henry, your tubing assignment is correct.
Digitech is has provided the best method for starter mounting alignment.
starter aligning is not that difficult.
you take off the starter cover (starter itself)
push the motor further in.
place the starter over the compressor nut.
now it will be aligned.
draw with a small marker around the legs position.
mark also where the legs are positioned!
drill the holes , mount and done!.
_____________________________
"www.digitech-turbines.com"
Dealers for:Wren-Turbines,Jets Munt,Graupner,Fei Bao.
"Home of the Jet-1A Gears"
Hi Digitech and Kerry,
Thank you very much for the tip and reconfirmation on the setup. Have completed the assembling and should be ready to take on my XL by end of this month I hope.
This engine has been serving me so well that I just transfer it from my Kangaroo to Rookie and then my XL. I'm pretty confident it will drive the XL with authority though I'm not expecting full out verticle.
Once again, thank you all for the advise.
Best regards
Henry
