RCU Forums - View Single Post - ignition problem?
Old 12-12-2006 | 09:51 AM
ShineyObject's Avatar
ShineyObject
Default RE: ignition problem?
Yes, the battery for the ignition was reading 4.9 VDC under a 300Mh load. I ajusted to richer setting with the same results. It acts like the switch is being turned off (maybe a switch problem?) ---- My real question was do the EI modules go bad? Is it common?
Thank you!
