RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 12-12-2006 | 01:31 PM
  #1016
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Try raising the cylinder. This will lower the compression both due to an increase in combustion chamber volume, and due to increased exhaust timing. If it runs well and to your satisfaction, then you could try increasing the intake timing to regain that lost due to raising the cylinder. Worth a try in all your experimenting.... The only downside would be a reduction in quench, or squish area which can be detrimental in the fight against detonation, but I don't think that is quite so critical in these small bore engines.
AV8TOR
