ORIGINAL: Mr. Nance
Hello all, was wondering if anyone has dealt with hobbytron.com before, just curious. Also i have never flown a plane with ailerons yet and am taking the cessna 182 4ch out for a test spin in a few days. any tips, will the plane fly ok if i just leave the ailerons alone for awhile? thanks a ton. Mr. Nance.
You are going to need to move the linkages on the aileron control horns to the outer most hole. It will help you control the plane. At the inside or middle setting the plane is way too jumpy. It will be easier to control the plane with the ailerons in my opinion as well. Instead of just using a rudder.
