RCU Forums - View Single Post - Engine swap
Thread: Engine swap
Old 01-26-2003 | 10:30 PM
TnNitro
Default Engine swap
depends, you got an old 1.5 or the new 2.5 they require different shafts. if you have the 1.5 depending on what engine you buy. megatech makes a .16 and hotboddies has an .18 that if you order the right one is a direct swap. if you use an O.S. you will have to cut the shaft. The new 2.5 Siro has an 18 just out that is a direct swap even allowing you to use the ez start.
