RCU Forums - View Single Post - OS 4D Carb replacement
Old 12-12-2006 | 03:32 PM
rainedave's Avatar
rainedave
Default RE: OS 4D Carb replacement
Thanks, y'all. Tower says the 4D has a 13.5mm throat diameter. A 13mm would probably work with some sealer and the O-ring pressed down really tight. The GMS carb is not remote and is 13mm. At $26.99 it's $30 cheaper than the OS. Do you think that will work?
