RE: YS 91 problem
The prop you are using isn't much prop, but at partial throttle, it should not be causing a problem. Try dropping back to 20% nitro fuel. If the problem goes away, the culprit is excess heat from the fuel. We use Cool Power 30% heli here and have great success with it.
Good Luck!
