ORIGINAL: downunder
The ideal setting is ... usually somewhere around 2000 revs below peak.
Brian,
If the engine peaks at 14K and you run it at 12K, the engine is only making only ~63% of peak horsepower on the given prop.
It is likely running at a four-cycle at this setting.
The alternate firing strokes when a two-stroke engine is four-cycling is significantly more powerful than the consecutive firing strokes when it is two-cycling.
I prefer to have the engine running a bit hotter and closer to peak (500-800 RPM less).
If the engine is in a consistent two-cycle at P-2,000 RPM, than it is good enough also.
