RCU Forums - View Single Post - Official HPI MT2 Thread
Old 12-13-2006 | 09:21 PM
  #10071
rcnz's Avatar
rcnz
Default RE: Official HPI MT2 Thread
ORIGINAL: 46u
A few pages back I was talking about this problems I have had ever since putting in my OS TZ. In MANY gallons with my OS 15 CV-RX never had a problem but since putting in my TZ I cannot keep the diffs together. I just total replaced my rear differential everything brand new but the out put cups and got a couple of tanks before messing it up again. The only thing it messed up was the pinion gear like you are talking about but took off about 4 teeth. Joebaby35 was saying the only way he can keep his from stripping is to run the alloy diff housing as the plastic ones just flex too much. I am going to try this after the holidays.
Yes, would be interested to hear where you can purchase an alloy diff housing from. As regards replacement, this should do the trick?
http://www2.towerhobbies.com/cgi-bin...?&I=LXTB55&P=7
Just wanted to check, as it is a different colour from the one included with the hardened final gear. I am assuming this is a direct replacement?
