RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 12-13-2006 | 11:46 PM
  #3187
msn_jrd's Avatar
msn_jrd
Default RE: U Can Do 3D
hey guys good to hear about the good weather we have been haveing unusual nice weather here too but havent got to do any flyin in the nice weather this stupid thing called work seems to get in the way but did fly over the weekend but like to froze to death (ya the weather changes kinda fast around here sometimes) it was 40 all weekend and 65 today!
but im putting the the u can do together the ailerons looking down them looked pritty striate so i put them on and turns out if i would have laid them down on some thing flat then one of them would have shown to be twisted (i new better but....) im going to try to attach a pic maybe it will work if you look close you can see but with the aileron in line with the center of the wing tip took a piece of 4 40 rod taped it in line with the center of the wing tip it stuck out past the end of the wing and made the ailerons match the rod to find center and then i looked at the other end of the a-rons next to the fuselage and they are not matching the pic makes it look a little worse but while the wing tip end is still centered i measured from the tip of the a-ron next to the fus. to the bottom of the fuselage and came up with 1and1/8 inch on one side and 1and5/8 on the other! now i was wanting to know what measurement i should be getin and while typing this i was thinking if i center the a-rons at the fus. and them being tapered they would probably be a lot less off so there for how close would they have to be to not be able to notice in flight that they were a little twisted and any suggestions on how to un twist them would be helpful too[img][/img]
