RCU Forums - View Single Post - ST 40, muffler and prop are stuck
Old 12-14-2006 | 07:23 AM
speedster 1919's Avatar
speedster 1919
Default RE: ST 40, muffler and prop are stuck
Loosen muffler clamp bolt and nut. If your in a hurry take a flat blade screwdriver and spread the muffler in between the slit . Not in hurry spray a little penitrating oil and the next day heat flange with heat gun or torch and it will twist off . Use gloves...........
