RCU Forums - View Single Post - Turbine Enforcer with Canards
Old 12-14-2006 | 08:32 PM
Wideopen
Default RE: Turbine Enforcer with Canards
Yes, nose was extended by 6 inches. Canards are mounted 24 inches in front of CG. Canards are 6-3/4 inches long at trailing edge and 3-3/4 wide. If I had to make them again I would make them longer and wider more closer to the composite-arf rookie with canards. Canards move up and down 1 inch with elevons, this was put on a switch. CG was moved 1-1/2 inches forward. Most of my ideas came from Joeflyer he has posted a link to his thread 4 post up from this one with lots of information.
