RE: I need your help with a conversion
AXi 2826/12 Motor
Jeti Advance Plus 30 ESC
13 x 8 APC thin electric prop
AXi 282602 Radial mount with prop adapter
PolyQuest 5000mah 5 cell LiPo
A few odds and ends connectors
Good charger and a balancer
Your in business!
Your first leap into electric is going to a bit costly if you go ahead and invest in a good charger and a good balancer.
You can proably do this setup for about 350-400 bucks. You could do the same setup on 4s and save a few bucks. That particular motor is rated for 37 amps at 60 seconds and the setup I mentioned above will draw around 28-30 at full throttle and fully charged and will provide around 9 pounds of thrust.
