Will the heavier weight of the Futaba 3101's make a diference in the overall flying ability of the plane or is it such a small amount of weight difference. Will they fit into the wing. I do have one HS55 along with the 3 Futaba 3101's. If I buy I more HS3101 and put the HS55's into the wings (if the 3101's don't fit)and cut the servo holes in the fuse bigger and use two 3101's there would that work.
So the if I get the 7.5 Li-po I'll be waisting my money cause when I upgrade to the outrunner motor I will need a 3 cell 11volt one.
What do I buy if I just want to get up in the air now - go with a Nicad or NIMH pack can I get a light 1500mah pack, what brand?
That way I can fly it for now and upgrade later. I'll just get the field charger that does both Lion and Nicad,NIMH that Maxx prod sells for $75
Would the Himax HB2815 Brushless 275 Watts on this webpage
http://www.maxxprod.com/mpi/mpi-262.html fit into the plane with no problem
when I want to upgrade.
