ORIGINAL: carmatic1
ORIGINAL: KyJoe340
It's amazing the difference small adjustments to the suspension, chassis, shock oil, etc can make.
its also amazing how well the nitro engine suddenly performs when a cold spell just swept through your local club and you run it with the mixture slightly rich
iF IT WERE COLD WOULDNT YOU RUN IT LEAN INSTEAD OF RICH?????? tHE COLDER THE TEMPS THE HOTTER (LEANER) YOU CAN RUN YOUR CAR. LEAN IS POWER. REALLY LI-PO IS POWER, BUT ANYWHO...........
