Sukhoi 26/29 plans
I am looking at building a Sukhoi from either the RCM plans (Su-26, plan no. 1074) or the MAN plans (Su-29). I would be using an OS BGX for power. From searching the forum, it would appear that the Mark Sirianni plan is not well drawn, is this correct? Also, the recommended engine sizes are .90-120, which I would think is not enough for an 80" IMAC plane.
Has anyone built the Sukhoi from the RCM plans? If so, what was the weight and what engine, servos etc. did you use?
