OverTheEdge: Yes I had taken the time to read the whole thread on your build very cool ...must say the wood in my kit is very heavy and will be using the hole method to lighten it up for sure... as a matter of fact I printed out your tail feather Pic and was considering the same ..but .. the T tail came to mind so will proceed with that for now unless after building the fuse I find it will not support it. I also like the idea of making the tip of the ailerons 1/2" wider.
I will also try to put the aileron servos on there sides and make hatch covers for them as well ( makes for a cleaner wing bottom ) The engine will also be mount sideways.
Have a few other mods that will be done ...but... will come out with them as I go along with the build
Check in often and let me know what you think.
