RE: Air Hogs Aero Ace!
Nova, not to sound to geeky, but when the pressure is in the 30.15ish range the plane flies differently than when the pressure is down in the 29.85ish range. I thought I was making it up until I was able to repeat the performance. The theoretical normal pressure is 29.95. That is fairly accurate for where I live. However, I can turn and stunt better with lower pressures. With higher pressures I can make serious altitude.
Tim
