RCU Forums - View Single Post - Master airscrews
Old 12-17-2006 | 09:19 AM
Villa's Avatar
Villa
Default RE: Master airscrews
I found that the standard cross wrench sold at hobby shops was too small to tighten the nut. I now use an adjustable wrench with a longer handle. Care must be taken since there is no limit to how tight you can make it. Suggest you start by using your current method. Then use a longer wrench and tighten it just a little more. Test it, etc.
