Not something for the newbies, but you can cut your clutch spring and re-bend it. It will give you better hole shots as well as better track performance, because the clutch shoes hit the clutch bell at a higher rpm. Its one of the tricks i found out by my clutch spring breaking. Two loops cut of should work for you.
