RE: Master airscrews
I use the same prop with my OS91fs, when I install a prop I will use a box end wrench and really crank the main nut down then tighten the lock fairly tight have not had any problems with loosening with the MAS.
the nut needs to be tighter than you would think necessary on 4st engines.
