RE: stripped gears help!! :(
its easy enough, take the engine out, you will see a screw at the end of the clutch bell, take that out, pull the bell off, take the bearings and washers out, pay attention to how you took them out, install the new clutch bell the way you took the old one off. make sure you mesh the gears good before you use it again, use a piece of looseleaf paper between the spur and clutch bell.
