RCU Forums - View Single Post - Sig AeroKote problems
Old 12-17-2006 | 07:14 PM
sarakj48
Default Sig AeroKote problems
I have used Monocote exclusively with good results but thought I would try Sig AeroKote on my latest project a Sig Kadet 25 converted to electric. I used A transparent Green for the wing and white for the fuselage I trimmed the fuselage with the transparent green, and the wing with white. The problem is that the trim will not adhere to the AeroKote film, it seem to but with a bit of encouragement will peel right off. Monocote bonds and cannot be removed. I am afraid that the duribility of the trim will not last. Has anyone else had this problem or am I doing somthing wrong? The AeroKote takes less heat than monocote and will burn if too much is applied. The streach seem to be less than Monocote. I am very dissapointed with AeroKote and will not use it again.
